Few more updates. I set the motor in the other day and realized the turbo hit the air box. I found out i had to turn the manifold and flip the turbo over. Its an easy thing to do but the turbo center was frozen in the exhaust housing. With some heat i was able to get it free so i could spin the center to line up the oil drain and oil feed line. Once i got the turbo apart i had one hell of a time getting the seal on shaft to compress and go back in its hole. I really hope it seals so we will see when i get it back together.
I also wanted to move both batteries to 1 side. It was actually really easy to do. I just mounted them on the left side and took the tray from the right and modified it from there. That way it uses the same hold downs and everything.
As you can see i have sprayed the entire inside of my truck with the spray in liner out of a can..this stuff is really cool..it add a little texture to everything makes it look amazing.
I went ahead and beat the back of the firewall in so i could clear the back valve cover as well.
And here is the manifold flipped over. It really brought in the turbo quiet a bit
