Anyone have an idea where to get a hydroboost pedal for a manuel trans. Tried a few local salvage yards but none in my area have it. Any leads would help.
Drill a 9/16" hole 3/4" up from stock...put shouldered bolt in ..check for fit mark for cross pin...remove drill for crosspin....put back in.....weld it in...cut off excess...cut old pin flush....now have hydro pedal.
Here are the pn for brick nose trucks. The lower is vacuum. The upper is hydro. Not sure if the pedal itself is the same from the bull nose but the brackets are not between generations.
Or buy an auto pedal and cut off part of the pedal itself (IIRC, the wider part of the auto pedal is all on one side of the arm, "offset" from center).
Besides the pin location differences between pedals there is another very important pedal difference. The auto tran pedal has a smaller diameter shaft hole than the manual pedal. A very well known member here was changing the pedals for hydroboost and purchased the auto pedal by mistake. He working on it cleaning it up and painting it and tried for a long time to install it... But suddenly found the shaft differance sizes. It was an awakening moment too...
