Gary, that WIF amplifier (black box above) I don’t think is in that circuit. The red/yellow circuit IIRC goes to the vacuum switch for the brake warning, I’m thinking headlights, and seems like something else but I can’t remember what. I do t think that circuit holds your answer. The red/green circuit goes to the IP; hot side of the temp sensor for the cold Advance/high idle; hot side of the GP relay; fuel heater.. think that’s about it. Did you by chance tap that wire for your electric fuel pump signal?
Maybe the fuel pump relay is bad?
