Machine Shop California
Shaker Breaker
Commiefornia
Sorry in advance if this info is already posted . I searched but found nothing . I'm looking for a machine shop in Southern California that does great work on idi's . My gasser machinist doesn't want to mess with it . Thank You !
Fozz
Camarillo, CA
I'm in Ventura County and used Speedys Automotive Machine Shop in Oxnard. They were recommended by my Napa guys (he does a lot of Napa's machining).
Not sure where in SoCal you are, if that would work for you.
Shaker Breaker
Commiefornia
I'm in Burbank but I don't mind driving to Oxnard if the shop is good .
Shaker Breaker
Commiefornia
I can't recommended any shops in my area. All hacks.
Dangit ! This is why I posted the question... seems like we've got a "situation" on our hands here in so cal . Hopefully someone in the region will see this and chime in with some good news .
chris142
SoCal
We sent a flywheel to napa to be ground. They somehow ground it .080 off kilter. I had to do that clutch job 2x. Napa did buy us a new flywheel. But if they can't even turn a flywheel they sure are not touching my heads or block.
Shaker Breaker
Commiefornia
Yikes ! Which Napa was this ? I want to stay be sure to stay away . Thx
genscripter
Inglewood, CA
I've sent my heads and other components to EMS in Inglewood. They are a gasser machine shop, but they are VERY meticulous and VERY knowledgeable. They are super old dudes that know everything about engines and machining.
I was just there the other day to have my bore taper and piston skirts measured.
I highly recommend them. Get in early. They have a lot of loyal clients and they usually have a waiting list.
JU57US
