Fellas,
Just to answer a few of your questions:
I did have to turn up the outlet of the turbo...total about 1/4". I had to do this to clear the intake plenum. The intake plenum I used was from a factory '94 Ford idi turbo setup. I actually found the last one available from Ford. I talked with ATS to try and get one from them. I thought they would be cheaper since they made it for Ford, but they weren't very helpful on the phone. It actually worked out well. Since this is a discontinued item from Ford they could sell it for their price.
To make it work with a hose attachment I brought it to a machine shop to have it turned down to 2.5". They chucked it up with the machined inside of the housing inlet. They turned it down so I had about an inch of material to attach the hose. This didn't turn out to be enough, so the shop that did the IC tubes welded an extension on the end. I'm really happy with this because they were then able to roll a barb on the end to keep the silicone hose on better.
There is quite a bit of material on the inside of the inlet side of the housing. This is where the factory turbo comes into the housing. This can mostly be removed with a die grinder or coarse grit drum sander on a drill press or hand drill.
The tubes were made by a local shop. It took me some time to find someone that would do what I wanted. The shop makes headers for NHRA top fuelers. So far I'm pretty happy with what they've done, but I haven't fired it up yet.
The intercooler is the standard aluminum PSD intercooler...found it on ebay. I looked at that radiator support for 3 weeks while I was working on other stuff before I could make the first cut. I'm not a big AC guy. It does get pretty warm and humid up here in the summer, but after looking at the situation the idea of having the IC high enough to mostly avoid the bumper and having a more straight forward shot for the plumbing over powered any desires I had of staying cool. I had to bend the front grill support and shim it up with a few washers to get clearance around the intercooler, but it all fits pretty nice. I've got about a half inch of clearance between the intercooler and the front grill support. The factory intercooler to radiator seals that come with the intercooler are actually pressed nicely against the radiator. There is about 1/4" to 1/2" of clearance between the intercooler and the radiator. During the whole process I didn't have to cut any of the heavier material that makes up the radiator support.
I have been trying to come up with some way of mounting the air cleaner in a different spot. I am really looking at getting it up front somewhere, but I'm going to wait till everything is mounted and running before I tackle that. I have found an intake off a Ford pickup with the 5.4 that may be the ticket, but I'm still working on this one.
If you guys have any more questions let me know. Right now I'm most concerned about what's going to happen with the temperatures. I'll get some info posted once I get it running
Oh and by the way...
Cab is from Montana, box is from Texas, doors are from Minnesota, and the front clip is a mixture of all of the above. Worst part of it all is that none of it is original. It has been a chore to try and find a body shop willing to help me out.
Paul
