F350camper said:
Thanks again for documenting your install, it’s helped me a lot while I try to piece mine together.
You mention that nothing mounts to the frame, and you like that. Could you elaborate on why this is important? I should be mounting mine in a week or so, and I'm hoping to draw from your knowledge.
Vibration and flexing. firstly, you will have all the harmonics from what the motor produces. Noticed how anything that is connected to the motor, ie. wiring, hoses throttle cables get tore up from chaffing if they are not isolated properly? That is the biggest issue. Aluminum is a soft metal and as much as I paid for the kit, I'm not going to take any chances of prematurely wearing it out. Secondly, flexing. These trucks, believe it or not, move around ALOT. They are designed that way. Otherwise, the sheetmetal will get shreaded. My F450's are notorious of tearing up cabs at the 500k mark. Park yours with one of the front wheels up on a curb and you will see what I mean. That is why the cabs and front clips are mounted on some pretty sophistcated rubber mounts. If it was for only noise isolation, you wouldn't be seeing that fancy of a design. therefore, any item hardmounted to the frame is going to get torn apart over time. This kit had isolation mounts between the IC and the core support and had two junctions on each side (IC to pipe and midsection of the pipes) for vibration isolation and for assembly flexing.
Overall, I felt this kit was very well designed. somebody put alot of work into making sure everything fit snugly and did not interfere with basic maintence. The instructions they sent with the kit made absolutely sense and only served to confuse and scare any novice installer into taking it into a shop to have it done.
On a side note, what IC are you going to be using? upstairs in the choker dept, there's a discussion of a 6.0 IC install into a early choker chassis. the mounting looks pretty good, how they hacked the crap out of the raidator support will scare you to death.
good luck!
PS.....final pics below.
