Going to add a parts list since i noticed some people looking for it.
Zf5 trans from an obs 460 or 7.3idi
The 460 trans will not fit unless modified and drilled
Pedal assembly from any obs 5spd
You must get a pedal assembly that matches your truck's year family. If you have a 86-dwn truck, you must use a 86-dwn pedal assembly. Not sure about the later year truck family interchange
Flywheel, i used LuK SMF
Clutch kit, again LuK's kit
Master and slave cylinder, i used LuK's sealed kit from rockauto.
Early truck firewalls must be drilled for the master. Later ones had a plate that just unbolts
Longer rear driveshaft
Shorter front driveshaft.
c6 to zf, driveshafts can be re-used, but some trucks used a different u-joint in the rear driveshaft
c6 to zf, lower crossmembers are the same, you need the short upper zf crossmembers to do the swap
Try to get the zf trans wiring harness. With a c6 to zf swap, the c6 harness unplugs under the brake booster, the zf plugs right in, you are ready to go with no wiring
The LuK clutch kit came with new bolts and the master cylinder position switch that will be absent from the E4od truck.
Crossmembers from F Super Duty trucks are different from the normal F series and will not fit.
