I have a 93 F350 with the nonturboed 7.3, with 285,000 on the clock. Had a leak in one return line and took it in to be fixed and now all the lines are leaking on that side. This mechanic is usually very good so what gives? He said that one side had larger o rings on it than the other side. I have had this problem in the past and maybe the last time they had to put in larger o rings? Anyone had similar problems with is engine?
