Leaking return lines
Ddizzy77
West
Hi, one of my return line caps was leaking. Replaced the o rings and no more leaks... so far. But, now it seems I have an air intrusion problem. Tried to start my truck, ran a few seconds and died. Turned it over a few times and it fired up, rough then smoothed out. Not sure next steps. Replaced the return lines and o rings last year, newer lift pump. Only thing I'm thinking is the rubber return lines weren't cut very clean. Maybe replace the lines again? Where can I find those little spring clamps? 1993 f250 7.3 idi NA.
Thanks
You need to look the system over very carefully. Look for any dampness around the caps, around any fuel lines up front, any return lines and check the top of the fuel filter, there is a o-ring around the fuel heater that can let air in. Not always but usually there will be slightly wet looking around were the air is going in.
If you have a area you are not sure about, get some brake cleaner and spray it, the cleaner will quickly dry it out. Then monitor it and see if it gets damp again. This stuff also works well for tracing oil leaks.
Clb
Another old truck
nannyfornia
Ok
Disclaimer....
I am knee deep in empty's
1 post, no search, no intro, no problem.
Its time for new returns.
And some reading.
It is all here for the time you spend reading.
Or we could hold your hand on the MOST common thread here????
Bahahaha velcomen
When did you have this problem? If you had it right after replacing the o-rings, then that is normal. You opened the fuel system and the fuel drained back to the tank. Does it still do this after you've cleared all of the air out of the system?
Ddizzy77
West
I replaced them a year ago, started dipping into the 20s recently. Cap was leaking, replaced the orings on that one. Ran it, no leaks. A little strange, everything was fine for the last year. Think new orings all around?
Ddizzy77
West
Ok
Disclaimer....
And some reading.
Bahahaha velcomen
My hands have been cold lately
Macrobb
North Idaho
Just slap a check valve between the lift pump and the fuel filter and call it good.
The lift pump internal flappers don't work perfectly as check valves forever... and if they get any crud in there, you get some 'drainback' if /any/ air can get in.
With a check valve to keep the /supply/ fuel in place, it doesn't matter what happens on the return side.
Personally, I just grab one of those squeeze-bulb primer bulbs. Internally, they are two check valves, and they are cheap. Plus, added manual primer if you need it.
Ddizzy77
West
Hmm, I replaced the lift pump three or so years ago. When I get a chance I'll try it.
Ddizzy77
West
Yup still does it. Replaced the leaking orings. Now it seems like air intrusion. My rear tank is also leaking, looks like it's coming from the top.
It may not hurt to replace the rest of the o-rings then. I'd think that they should be alright since they are only a year old, but there was another injector that had leaking o-rings that were a year old.
Ddizzy77
West
Thanks, I was thinking that. Seems like everything started leaking at the same time
How can that work when you have that return line going down the rear of the engine to the tanks? That is a major highway for the fuel to return to the tanks if air gets in somewhere.
I don't know why anyone hasn't tried it yet, but I always thought a electric solenoid valve in the return line would help stop this. Activate it with the key in run, turn it off and block the return line when the key is off.
I believe the factory already has a check somewhere in the feed system on the pass side front. Not sure if it's in the filter head or somewhere else.
Pork_Chop50
He looks kinda hairy and slobbery to me....
Willamette Valley, Oregon
And also the lines themselves can check and crack over time. I've replaced my hoses twice now along with caps and o-rings. I would take typ4 up on the offer and start over with a whole new setup. The fuel heater o-ring and injection pump line olives should be replaced as well.
mitsu tractor
