Leaking return caps
vegas39
las vegas, nv
Good morning all. Just curios if anyone is having return line issues and how long you're getting out of a set of O rings. I replaced my return line system 4 years ago along with my injection pump and injectors, that was at 164,000 miles. I now have 202,000 miles and every return cap is ******* out fuel. Seems to me like we should be getting better than that outa these. Is it the fuel we're getting nowadays?
TNBrett
Middle Tennessee
Not all O-rings are created equal, neither are all return caps. If the caps look ok try replacing the O-rings with Viton ones. Do a search on here for the size as it’s been mentioned several times before and I can’t remember off the top of my head.
Big Bart
Tow&Slow
Newport Beach, CA
Some have suggested the braided hose did not last many years either. As TNBrett mentioned members seem to like the Vito ones. Might just be time to by a new kit and upgrade the o-rings.
lakesurfer
Smyrna, TN
Assuming @typ4 is still kicking, I bought my last cap, hose, & o-ring kit from him and it has been great. Also, consider using the "Zicam Bottle Cap" method when installing the o-rings to minimize nicking them. Procedure is in the tech stickies.
I know from McMaster-Carr you can buy Viton "O" Rings
in bags of 50 for around $8. size 111.
You don`t always have buy a whole new kit.
Last time I changed the return hose, I bought
rubber hose from O`Reillys. Cut to size, used the
spring clamps, and new O Rings. Be sure to replace
each side as an assembly.
If using rubber hose off a roll, it wants to stay the
way it was rolled. I put one section curved one way
and the next the other way to keep it straight. Worked
good and no leaks the past few years.
vegas39
las vegas, nv
Ok, thanks for the info. Yeah, I tried using the braided line and it leaked right off the bat. I switched to rubber hose and it's been fine but like I mentioned, all the caps are leaking. I'll see about getting the Viton O rings for it and tear into it.
The_Josh_Bear
Western WA
One of the best tips is to lube the o-rings well. Grease works great and doesn't hurt to mix with the diesel. This is of course with Viton. My set from Russ @typ4 is going on 7 years or longer, did at least two kits before getting the good stuff from Russ.
Cubey
Van dweller
USA
I used cheap petroleum jelly on the o-rings for both my F250 and RV and both have held up fine for 3-5 years so far. Being more tacky, you're not as likely to drop the o-ring from being so slippery like with grease.
zemmeron
