plywood
Recovered N/A
So I spent a day at the junkyard a while back looking for parts to use for cold air and intercooler setups.
I posted the intake hat earlier and the accordian looking hose in the pics is from that same vehicle.
So this air deflector is from an Expedition, the airbox wasn't there so I just used the half piece I found and cut it to fit.
This is a 5"x9" K&N air filter, fits if you shove the battery all the way over.
I'm hoping I can turn the battery 90 degrees and then the aircleaner will fit even with the A/C installed.
I don't have an EGT so no news there.
When the truck is running, I can put my hand down at the deflector and feel the hot air blowing on it.
I'm guessing it has pretty much 100% cold air once the truck is moving a little and getting air in through the core support.
