93fordturbo
I used 1 inch expandable plugs. I'm pretty sure they seated good. I just wanted to see if it would hold water. I replaced the one buy the oil filter,it was pretty easy. Replaced the one by the oil cooler, I had to remove 3 bolts to jack the motor up and get at it. Was a real pain. I can't find the other plug. I found two on the passenger side, one is the correct plug, the other has the block heater in it I think? So maybe there is just another plug out I can't find. I just wanted to see if it held water before I go and put the correct plugs in
