Ask an unclear snippy question, expect an unclear snippy answer. If you want someone to go to the time and effort of typing out a useful and clear answer, the least you could do is be clear exactly what your question is and act appreciative.
If it's the plug under the motor mount you may be best off pulling the motor unfortunately. You need to be able to get clear direct access to the plug to get in there with the proper tool and a hammer. IIRC that plug winds up directly in line with the cross member, so even once you jack it up and pull the mount you still can't really get in there well.
Further, these engines use disc plugs, not the more common dish plugs. This means that installing them is somewhat harder and ideally requires a special tool, and further, you cannot just stick a rubber expending plug in like you can with cup plugs.
I'd jack under the harmonic balancer (making sure to use a board and jack the balancer, not the pulley) or possibly the oil pan making sure to use a solid board to distribute the load.
~John
