Is this an idi or psd??
Jhall
Florida
That’s what I thought. Thanks guys. The truck is immaculate with 170k. The owner is asking 6500. Is it worth that?
Macrobb
North Idaho
What are other similar trucks going for locally?
Admitedly, my rigs aren't the prettiest, but I've picked up two OBS turbo idi extended cab 4x4 trucks here for <$2k.
I'd see a pristine one as being worth 3k, 3500 maybe if it's really nice. Remember, it's still 25 years old and you will have to put work into it - seals, injectors and such - within 20K. Just because old rubber is still old rubber.
Not that that's a deterrent to me, but 6k is a lot of money to me.
Around here that price is a bit high, but if the truck has been well maintained and has a lot of new parts it’s not that far off. I’d say 5k is a fair price but I’d try to get it for less to be a good deal
Jhall
Florida
Thanks for the info fellas! So definitely change glow plugs and injectors asap?
Injectors and injection pump should be changed at the same time, I would pull the glowplugs and if they aren’t motorcraft I would immediately replace them
Jhall
Florida
Any particular brand I should use for the ip and injectors?
Jhall
Florida
Right outside of Jacksonville in a little town called Yulee.
77f250diesel
Florida
Was just thinking you'll need your truck timed after new pump and injectors and if you were close enough I could help you out.
Your probably abt. 3 hrs. from me.
