gearhead
Currently I am letting my oil settle for a week in a 55 gallon drum then I drain off the water at the bottom.Then I pump out 5 gallons of oil to be ran through a bowl style centrifuge twice.However, if the oil has a high concentration of water the oil has to stay in the centrifuge for much longer just to clean.The first pass through the centrifuge is full bore or how ever fast engine oil flows through a 3/8" hole under gravity.The second pass I throttle the oil to about 1-3 GPH depending on how wet the cake in the bowl is after the first pass. Lately however, I got some oil with a high water content and a month later I am still draining out emulsified oil with some free water.The net affect of that is the second centrifuge pass has to be slowed to about 1/2 GPH to get a good dry cake on the bowl which pretty much makes it take all day to make 5 gallons of fuel for my truck.So right now I am looking for ways to speed up the settling or water removal in the oil tank.One way I heard about is called headspace dehumidification.Dry air is forced into the tank and wet air is allowed to vent out.I am wondering if it would work better if that dry air was introduced at the bottom of the oil then allowed to vent out the top?right now I am just trying to get my batch time back down to about 1/2 a day because it sucks waking up at 7 to start the process only to pour the finished oil into the truck at 10 PM, in the dark...
