Intercooler w/ wide radiator
laserjock
Almost there...
I'll let you know when I get it all on the road. Check my build thread. You are looking for late December early January time frame. My install mirrors the one in the tech articles with my own flair since it's a different turbo. F250XLTHD (I just butchered his handle) wrote it up for a Banks.
pelky350
Springfield, OR
I was contemplating getting the full kit for 150 that comes with a intercooler and a bunch of 2.5 piping kit anyone use one do they work kinda good for the price? I feel like it can't be that good but maybe get by until I buy a better intercooler? Still having trouble deciding bar and plate or tube fin and the size I should be getting the bar and plate has it listed to support 400hp and <600cfm is that sufficient?
pelky350
Springfield, OR
Ordered cx racing 31x12x3 cooler and 2.5 piping kit and a couple adaptor boots, typ4 gets back to me tomorrow on eta of intake hat and soon I will have a full intercool system hopefully it's gonna be worth the effort and money! :peelout
pelky350
Springfield, OR
Got the cooler, the piping kit in mail and got intake hat from typ4 before he left for vacation, just a couple of boots and brackets making and it will be ready to install! Results to come soon with pictures and parts list for others who want to intercooler with "wide" radiator and a 088 ats system :Thumbs Up
shawn deere
So many wrenches, so little time...
nebraska
Hey there. Can you do me a solid? Ive heard some one some where at some point say that an intercooler would increase the turbo lag. But others have said it wont matter much.
Can you keep an eye on that before and after intercooler turbo lag for me?
If i rmember right if a guy keeps <10psi the heat rise isnt too bad
Are you rocking 15psi with head bolts still?
laserjock
Almost there...
Intercooler will cause some lag due to the extra volume. If it's sized correctly, it probably won't be noticeable and the benefit of reduced temps should far outweigh the negatives.
pelky350
Springfield, OR
Stock head bolts for now, only 170k on motor, no head gasket failure yet but only been running that a short time and only briefly at wot. I am also wondering about the turbo lag but I've done things to improve on that pre instal, wrapped up pipes, 4 inch exhaust straight pipe, large intake and filter not the 088 box. I'm not too worried about loosing some boost or a little lag because I want my motor and set up to last a while. Hoping I sized everything correctly enough that I shouldn't have to worry about lag and boost lost. Kinda set it up to see if everything I need is there, just need one boot to connect to turbo and then I can hopefully instal theoritically it should fit taking measurements later today from truck. So far still under 400$ budget I set for myself but we will see lol
pelky350
Springfield, OR
Now with some measurement I took between rain showers, I've come up with a different looking mock up that should be close to what will go on in a few days hopefully. I'm more conserned about turbo lag now having to use pretty much every piece of the universal kit I got, hopefully it's not too bad I hope I don't have to buy any more pieces though!
D_Fresh361
Victoria, TX
Lookin good man. Is your turbo gated or non? I like that hat in place of the ATS hat. Especially since the original didn't have to be modified. ;Sweet
shawn deere
nebraska
Looks sweet man! I wouldnt think you would lose any max boost. And the intercooler looks sized good to me.
Pulling hills and dyno run i wouldnt think a little extra turbo lag would matter much
shawn deere
nebraska
Just put a WW2 on today
Had the turbo off but couldnt split the exhaust side clear off to get a wrench on the shaft.
Got the exhaust snail where the waste gate flap is. Had to torch every single bolt to get that far. Theeeeen there was an odd nut on the exhaust wheel. Had to use an impact and vice grip to get the stock compressor wheel off
IDIBronco86
Staff online
