Yes But.... I can't - don't see what the fitting is on the end of the pressure line.... That unit is just a remarked Rotunda tester. I have two of them. On works and the other doesn't... The buy it now price is a fair price too. Buy it. The worst you may find is you need a fitting or differant line. Those parts are available last time I checked. I have the part numbers if needed...
Dad made one the other day from an old Power Team hand hydraulic pump and an old IDI injector line. Works well and I pop tested all the injectors on the crew cab before reinstalling them. The injectors opening range was a bit wider than I'd like, but the patterns were all great and none of them leaked. The lowest opened at 1650 and the highest at 1800.
