Injector line heaters for 7.3 idi
mjs2011
Brookings, SD
Fattywagons.com sells injector line heaters to heat your lines up right before injection. I have been running on wvo and want to install these heaters.
Has anyone used these before? Will they be effective with the return system flow that these IDIs have?
Sent from my SCH-I535 using Tapatalk
I see it helping cold starting, but you would probably need to let them run 10 or so minutes before starting.
I don't think it'd be that beneficial.
Maybe a plate heat exchanger.
mjs2011
Brookings, SD
I have a flat plate, heated filter, etc.. But these aren't to eliminate other heaters. They are to raise the oil temp to approx 250 degrees, which helps combustion. I have no issues starting, as I run a two tank system so I start and shut down on diesel.
I just wonder if the fuel flowing through the injector lines is too fast to properly heat on the IDI, since these heaters were designed for the Mercedes diesel.
The FNG
NOT a Powerstroke!
Goldendale, WA
I was looking into a 12v or 120v silicon heater to wrap the filter with. I'm kind of torn on which one though. A 12v you could use while driving with a switch, but the 120v wou could use like a block heater and plug it in overnight.
mjs2011
Brookings, SD
I chose the 12 v and will work it with a switch.
Check wvodesigns.com
They have both 12 and 120v filter heater wraps
Cv axle
