Injection pump gear
Exekiel69
How many teeth are on this gear? The tach reads from this gear and I'd like to know how many teeth are on it.
Thank You.
That question has been asked before. I counted it and posted it here long ago. I'll try to find it.....
Exekiel69
Yes, that is exactly why. In the cummins has as many teeth as the IDI on this particular gears then I can adapt it and may get an accurate reading.
Exekiel69
Even if someone has a picture of the injection pump that will help I can count the teeth from the picture.
To bad you didn't make the IDI Weekend. We had an IP gear there for your viewing pleasure, and you could have checked out Darrin's conversion too.
Exekiel69
I know, I wanted to make it but I couldn't. He didn't get the tach to work like I want it, I'm intending to use most of the ford gauges since the cummins doesn't have many.
Anyone have an engine around to look and tell many how many teeth does it have on the IP gear?
Thank You.
m2rtin
