in search of unobtainium
Clb
Another old truck
nannyfornia
after I get sent a 3/16" return lineset with a pump and bb's and set about installing it........
several days later imagine my surprise to realize I removed a 1/4" lineset... get to # 8 and realize the t for the tank return is 1/4".
before I shell out for another lineset in 1/4" anyone know of a 1//4x1/4x3/16 metalic t?
Draw an strait line left to right... In the center on top draw another line(branch)... Left to right line would be 1\4"... Branch would like to be 3\16"....
Barb fittings.
napa stared at me. truck co here on the edge of the black abyss aught (sp?haha) at me.
jwalterus
Made in America
Garrison, ND
go to a plumbing supply store or hardware store, should be able to get one in threaded or barb
Clb
Another old truck
nannyfornia
you have NEVER BEEN TO NAPA have ya? lol
now If you want a bottle of wine, just swing a dead cat around.
but thanx cb
All the return line system fittings has to be either 3/16" or 1/4" fittings. There is no such fitting (cap) (1/4x1/4x3/16) anywhere that will fit on an injector. Whoops, need the fitting below, not a cap.
If the original is 1/4", then the barb fitting on top of the IP is also 1/4", also the barb on the filter, if it is 3/16", those barbs will also be 3/16".
Below is probably what you have. You could drill and tap it for a 3/16" barb, 1/8"NPT to 3/16" barb.
EDITED
jwalterus
Made in America
Garrison, ND
I have a Napa, carquest, oreilly, AC Delco, and a couple others in town
I go to napa for electrical items and filters I have to have that day, anything else, they are my last choice, especially plumbing type fittings
Clb
Another old truck
nannyfornia
Thanks bill.
You gottit.
I'm just gunna go get a 1\4" return lineset.
As the rear t block is staying stock.
It really sux when I ordered a 7.3 lineset and they shipped one marked 6.9-7.3.
But you know the drill.
70 usd on obn.. Or 35 china dollars on epay.
Rant over.
Clb
Another old truck
nannyfornia
I got vatozone o really'$$$ and napa
All 3 carry the same part from the slow boat.
Napa just rebox's and marks it up.
Heck even the old family heavyweight truck (class8) shop has the same craptastic selection.
Cannot even get spring pins ( center of leaf) unless ya order a case.
remember the return line behind the block is 5/16
I got my chit from ACE
Clb
Another old truck
nannyfornia
Page locked
Yes sir!
THanx...... amazing the 6.5 printed on the canada bits under there.
any return line with green clamps is going to be the small 3/16 lines. The red clamps is the 1/4 inch lines.Never mix and match cause you will have plenty of leaks no matter how you do it.
Macrobb
North Idaho
You can always just use a 1/4" tee and shove the 3/16" line onto it. I've done that before, it generally works if the rubber is stretchy enough.
zebrabeefj40
Pepperell MA
Or use the 1/4" tee you have, a short length of rubber hose to a reducer like this one from McMaster https://www.mcmaster.com/#44555k116/=16ivbga (or Home Depot/Lowes equivalent) to get down to 3/16".
Or you could build your own reducer tee using a female threaded tee and three NPT hose barbs 2 -1/4" and one 3/16" - if you have room. Use liquid pipe dope if you go this route not Teflon tape.
Nick
IDIBronco86
