IDI into a military truck
Simp5782
SNOW TACKLER!
Western MT
Yeah it is, Its a 72 M818 we added a second cab to. I dont know why it wouldnt fit in an IH they came with 392s in some of them and its wider than the 6.9 and twice as heavy
f250ap
Wilbur, WA
I thought it would fit but wasint for sure. I like the the IH pickups cause there built like tanks and with an IDI It would be a pretty sweet ride
wmoguy
Colorado
Got any pics of that one?
Simp5782
SNOW TACKLER!
Western MT
here are a few pics. and a few from when i made my 20k drop hitch with the frame off resto.as well as my M816 wrecker that i recently sold.
wmoguy
Colorado
I love that thing! What's something like that double cab sell for these days?
Simp5782
SNOW TACKLER!
Western MT
U can't buy em at all. You can pickup a decent m818 from 2500 to 6k from gov liquidators or other places. The cav conversion ran me about 3k for all of it. Are u wanting to buy one? Text me at 901 500 3188 if u r.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
simp, are you saying a 392 is bigger? its a SV motor, weighs around 800-850ish and is just a little bit smaller than a 6.9. the scouts came with a 345, and they're the same thing as a 392. the 6.9 in my scout fills the engine bay a bit more than a 345.
I agree we need more IDIs in things. My dad was wanting to get a 71 or 72 IH pickup and do a 7.3 IDI in it. Would it fit?
f250, a 6.9/7.3 is a perfect swap for them, they have a ton more room than an scout and the best part is it's pretty straight forward, if you use a 2wd trans you just need a jack shaft. check out the binderplanet.com there's a few people that put them in IH pickups. if yoy have any questions just ask, i have a few D series pickups too. ;Sweet
Simp5782
SNOW TACKLER!
Western MT
The 392 is wider manifold to manifold than the 6.9. The one i have is 2ft 6inches across, and the 6.9 is 2ft 4 inches across. Hint why I think i might run into a problem on my 6x6 is cause the frame 2ft 2inches wide. but with the sae2 adapter it will sit up higher out of the frame. Weight wise I dont know which is heavier.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
weird, i never measured, but the manifold almost hits the steering bar from the box to column in my scout, i actually had to loosen the column and turn the whole thing a little to get around the 6.9 manifold. the 345/392 clears in a scout engine bay with rook to spare! :confused:
Simp5782
SNOW TACKLER!
Western MT
not bad. yeah they sold a couple of those up here at the afb with less than 200 miles on them in 818s for $2800 or so each. cause it was so far noone would bid. that one will go for 4-6k more than likely . 818s are good but u only get 4mpg from the na250 cummins. and u need to put a jersey barrier on the back of it if ur gonna drive it around because they hop pretty bad going down the road. All of my trucks that i can put them on the back get 2 jersey barriers strapped over the rear axle. My 5 ton even with holes in 2 pistons would go anywhere with the barriers on the back and chains all the way around with duals up front. it was FUN!!!
5 ton trucks like the 818 are nice but the only issue is that the transfer case is a sprag operation unlike the deuce that has a air front engagement.
The dual one in the picturee is a buddy of mines... the other one is an M813, basically what an 818 is just with the cargo bed. It is located in west virginia and is for sale for $2800 if anyone is interested let me know.
trapper
Boom Boom
Chatsworth Georgia
i use to drive a believe what was a 5 ton 818 with a dump bed, it had the multi fuel in it i loved the thing haha, and what the deal with the what sounds like a air lock reverse ?
RangerDanger
