Aug 29, 2015 #1 NTOLERANCE I'm the cotton swab Joined Dec 29, 2010 Posts 714 Reaction score 1 Location cottage grove, wi Is the zf the same idi to ps? Flywheels the same?
Aug 29, 2015 #2 OLDBULL8 Good Morning Ya'll. Supporting Member Joined Feb 12, 2009 Posts 9,923 Reaction score 338 Location Delphos , Ohio What yr. PSD?
Aug 29, 2015 #3 79jasper Chickenhawk Joined Oct 13, 2012 Posts 17,367 Reaction score 1,930 Location Collinsville, Oklahoma For the 7.3 powerstroke, yes. The zf 6 is a little different though. Flywheel should be different. Sent from my SAMSUNG-SM-G890A using Tapatalk
Aug 29, 2015 #4 IDIoit MachinistFabricator Supporting Member Joined Aug 26, 2014 Posts 13,324 Reaction score 3,897 Location commiefornia im 87.5 % sure they are different from N/A to PSD due to balancing. ill take my flywheel from the 97 PSD to my 89 IDI tomorrow
Aug 30, 2015 #5 IDIBRONCO IDIBRONCO Joined Feb 5, 2010 Posts 12,399 Reaction score 11,141 Location edmond, ks The flywheels are different. There's 10 crank bolts for the psd and only 9 for the idi. The zf5's are interchangeable IIRC.
Aug 30, 2015 #6 Double-S-Diesel parts seller Joined Mar 8, 2005 Posts 2,520 Reaction score 77 Location derry pa flywheels are different 5 speeds the idi used a zf42 and the psd used a zf 47 little different first gear ratio. I used one from a 89 in my 96.
Aug 31, 2015 #7 BrandonBerkosky Full Access Member Joined Feb 2, 2013 Posts 481 Reaction score 1 Location Dickson city pa Zf5 First and reverse are different. Just use the idi clutch parts.
