I hate bodywork...
FordGuy100
Silverton, OR
I hear you!
This is where I am right now
Dsl_Dog_Treat
Decatur,MI
Aww suck it up cupcake.
In the same boat with ya Jason. Struggling to stay motivated today.
Old Blue
Salem, OH
I've been conveniently ignoring my own bodywork... Don't remind me!
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
:shocked: :shocked: :shocked: Holy rusted-out cab Batman!!! I thought my rust problem was bad...I never thought I'd find myself saying this, but that's even worse than my old Scout was :shocked:
Is that even salvageable?!?
kc0stp
30 Hour Famine
Colorado
Sure...easier to just put a new floor pan in instead of patching though
Devon Harley
San Diego
no whole floor pan much easier tho get the step rail and half the floor out of the junk yard cut that out and add the whole bottom side piece a whole floor pan gets to be to much work alot more fitting its never the same
Old Blue
Salem, OH
Yeah, it's not as bad as the picture makes it look, but very similar to the kind of work freebird01 is probably dealing with right now, mine might be a bit worse. About 1 1/2" of outer rocker will be replaced with the seam for the door weather strip, about the same amount of outer floor pan will be replaced along with its seam area. These are all patch panels readily available, I only need about 25% or so of the entire patch panels' area that are available to fix these little holes. I also have to fabricate the inner rockers, which are about an inch wide or less, and butt up against the outer rocker seam and the floorpan seam. You can buy the inner rockers too, but its cheaper just to bend those parts on a brake, no fancy stampings required or anything, unlike the other bits.
The main flat part of the floorpan is in good shape, cab mount areas are good, and cab corners have no rust! The picture makes it look like the whole pan is a rusty mess, but that's mostly just rust dust and chunks coating that asphalt sheet in there. The little cab mount bolt access plate is rusted to smithereens though on the drivers side - this happens because the wool sound deadener gets wet under the rubber mat and never dries out, and it's not painted! :eek:
This is what happens when you improperly fix a northeastern truck with bondo slathered on thick on cab seams underneath like the P.O. did. This was a PA truck and this is common over there because of the "no visible rust" inspection they seem to have to pass yearly. These cheap fixes make it degrade much faster...
Exekiel69
Doing this on the 84 IDI and on a 92 CTD dodge, not fun but sure feels good when it is done right.
freebird01
Post Turtle!
Fort Wayne, IN
naw i dont have the extensive floor pan damage...but im finishing up the pass cab corner and half the underside behind it was rusted. had a few spot patches where screw holes rusted out further....
i think im done welding on the cab now. just had to finish putting filler on the corner and smoothing it out. i have a hole to patch in the pass door....fix a few dents and start hitting it with primer. i still have to do wheel lips on the bed from my ext cab to put onto this 85 reg cab.
i also ran over the floor with herculiner too so thats drying right now.
freebird01
Post Turtle!
Fort Wayne, IN
I hear you!
dont want to hear it there spanky LOL
you can walk away from that if you get frustrated for 3 days and come back and start again and it would still be nice and clean...if us east coast guys did that it would covered in rust!!!
The Warden
MiB Impersonator
How does Herculiner compare to POR-15 or similar in terms of rust prevention/inhibitor? Not so concerned about appearance; just trying to keep the salt air from eating my frame alive :shocked:
freebird01
Post Turtle!
Fort Wayne, IN
i would stay with POR or SEM rust shield. my initial thought was to use the herculiner as more sound deadener but it went on thinner then expected....
Cv axle
