i put in beru's on fresh installs. when the glow plugs eventually burn out and they will sooner when the timing is advanced. my truck goes on a ether diet. i know the risks using ether. nonone need to mount a crusade in dissuading me on doing so.
i used starting fluid for a few years with my diesel wood chipper.always just a little squirt while cranking.recently when i went through it,i had the relay replaced so she now starts again with the plugs.
id recommend running burnt out Beru's and starting fluid long before i would an off brand plug.
I had four of each in mine until recently. Installing eight new Motorcrafts highlighted the deficiencies of my glow controller. So it got replaced with Motorcraft as well.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
