Waystro
No Class
Pulled a GlowPlug tip is broke off
Just cranking it sounded healthy. It was a Autolight.
For now I'll run the wellmans and spend the coin on berus later.
The 088 wellman plugs I got cost me an engine rebuild after all of them lost their heads.
All I can say is do a test on them before installing anything other than beru plugs in your truck
Tried both wellmans; the 080 is the direct drop in replacement. That resulted in every tip falling off and me planning a rebuild when the plugs stayed on for too long. I bench tested a wellman 088 and that resulted in the tip swelling up to about 5/16" before finally dying.
They are crap and may cost you an engine but if you insist on trying them at least test them before putting it anywhere near your engine.
I failed a set of berus due to a failed controller and they all came out in tact with no harm done to the engine.
Diesel Rx's Wellman plugs seem to die an early death (in my experience) just like all the other non-Beru/Motorcraft plugs out there. Their controller is still working OK but the Wellman's went; 1 the first week, 1 the week after, 2 more the fourth week. Ran on 4 plugs for 4 or 5 months until I replaced with all Berus. Eight months on the Berus now and I'm still getting 8-9 seconds on the wait to start light...
Not me I'd take the money and run.someone could offer me 2 grand to run a glow plug other than motorcraft/beru in my idi engines and i would decline.
