How many First Gen. guys we have?
u2slow
bilge rat
PNW
Left my white '90 D250 at home.... travelled ~5000km to go to school and found another 5 mins down the road :sly
draginmopars
Nashville,tn
This 73 is a want to be 92
had a little rust issue
so we married a 92 firewall to the 73
was a440/518
now is Cummins 5 speed
http://ramchargercentral.com/diesel-talk/1973-cummins-hauler/
we are building the car hauler to carry the Rampage
The Rampage has no rust issues, just power problems
we fixed that
draginmopars
Nashville,tn
This 92 is my girl friend's truck
she fixed it up
5 speed with 11 foot bed
http://ramchargercentral.com/diesel-talk/looks-like-a-different-truck/
I helped her with
u-joints, tires, brakes, change fluids and filters, etc.
she did the sanding and paint, stripped the interior, pressure wash the carpet/install
remove the 8' tool boxes from the bed
and she replaced windshield
use it for haulin the tractor/mowing the farm
going to the river, 500gal water for the garden
Then we added the "Ram" head on the hood
and a home made tire carrier
and a storage box, (was an airline food tray carrier)
Now used for chains,tie down straps, jumper cables, flags, wide load sign.
last thing was add an extension to the exhaust
to keep from dis-coloring the mud flap
Some days
help move or haul airplane parts.
79gmccrewcab1t
idaho falls id
New to the site and new to the world of owning a 12 valve
My truck it a 79 gmc crew cab dually,been planning this build for bout 7 years(divorce screwed it all up) just aquired a 12 valve ffrom a school bus.ID tag reads 8 of 1989. Will use for moderate towing, some highway but mostly in town. would like to see 300 to 400 pony's from it. Engine had bout 160,000 on it and run like a clock. Gotta love the ol 12 valve. Still undecided on the trans. allison 1000 is way out of budget and dont want a stick so prob go with some taller gears,tires and use the 545 allison for now
ellis
kelso tn
well i just got my dads truck 92 dodge diesel ext cab 2wd and 330.000 on the clock and still going stron and it is a auto and the trans has never been into.
chvycmnslvr68
Ponca City OK
what part of ks are you in .. i just moved to denver from northern OK and i have to go back to get a few things ... maybe we could meet and see each others conversions and compare likes and dislikes about the way things were done .. one of the things i have to go get is a 92 toy 4Runner with a 2.2ltr turbo isuzu diesel conversion .. 50MPG ..
buck board
river falls/wi
Just joined! 1990 w250 with 93000. Bone stock, original red over white. Bought it from my Dad 17 years ago. The white trim was pealing (very typical), so its in the shop getting the white re-shot. Awesome old truck. I've towed 9000lb loads from California home to Wisconsin twice no problem! 14 mpg at 55-60. Not bad for the stock 160 hp! Its got the three spd auto with 3.09 axels. Three solid days on the road, and your pretty well beat to death though!
Grey Wolf
Acton, Ca
;Sweet Your handle is exactly what I tell people about the ride qualities of my truck, but you already know that:D Regardless it's a great truck! GW
Bytesmiths
Cascadia Bioregion
91 4x4. Searched five years for it. Didn't want computer-controlled injection. 300,000 kms and going strong. Changed front brake lines and rear U-joint. Power steering pump seems to need topping off quite often. Gonna drive it until one of us quits. :_)
RetiringColt
Washougal WA.
Hello all! Joined back in March. Haven't quite figured out how to post pictures yet, but I've got a smooth running 90 W250. Built a fresh 6BT for it. Went full retard and spent too much money. Rebuilt the getrag made an oiling system for it. Electric oil scavenging pump with cooler and spin on filter. Puts the clean cool oil on the input and output bearings. The list for the engine: ported head (done professionally), Hamilton oversized valves, dual valve springs, Hamilton HD push rods, Hamilton billet lifters, Hamilton billet torque cam, cam bearings in all the journals, Commetic head gasket, ARP head studs, 20 over marine pistons, gaples rings, ARP rod bolts, gorilla gurtle with 14mm main studs, harmonic fluid damper, southbend clutch kit (custom single disc), balanced rotating assembly, low pressure piston pump, hungry diesel built VE pump and hungry diesel built injectors. I believe they were similar to the 370 marine but 5 hole instead of 4. Also a Holset HE351 with billet wheel and ATS plug. Went for the God Speed intercooler kit. Had to buy some extra silicone hoses. 4" exhaust all the way out. Probably forgot something but that's about it.
u2slow
bilge rat
PNW
Forgot about this thread. I guess its time for an update... ;Really
Rug_Trucker
Pertnear Nashville TN
she fixed it up
I helped her with
Some days
Where you at now Howard?
olsen726
