How Hard of a Brake Pedal for Hydroboost
tuckerd1
WAR DAMN EAGLE!
Princeton, AL
I finally got my hydroboost brakes installed. I have ~1" pedal travel hard as a rock. I haven't even bled the wheel cylinders yet.
How much travel and how hard should it be?
Some useful info to come later.
Exekiel69
Did You have to move (up/down) the pin on the pedal that push the HB rod? The rod must be level or be able to push straight IN not in an angle.
If that isn't the problem, have You made sure the HB gets ps fluid yet? If it is then make sure the return isn't blocked.
Exekiel69
I moved the pin up on the brake pedal ~ 3/4". It is level now.
So You drilled a new hole for the pin on the pedal arm then, if it is still hard I would make sure it is getting ps fluid and returning it to the reservoir.
tuckerd1
WAR DAMN EAGLE!
Princeton, AL
Took it for a test. It will slide the front wheels. Not sure about the rear. They need adjusting still. No softness to the pedal at all. I don't even know if the pedal is movong an entire 1".
Brakes are strong though!
sootman73
Wauseon, OH
i'll trade ya!;Sweet;SweetLOL
i wish my truck had brakes like that! mine go too far down and are too soft. i like a hard brake pedal.
tuckerd1
WAR DAMN EAGLE!
Princeton, AL
I'll start a new thread with parts list. We have plenty of tech articles to tell you how to do it.
Glad you got it figured out. Mine works the same as yours does. I was really surprised at how high the peddle is when it comes in to the braking action. Remember you now have just a little more than twice the brakeing pressure available at your foot. Did you install the 1 5/16 inch master cylinder? I did and wow is all I can say. Its so much better than vacuum assist braking. I no longer have the peddle near the floor before its stopping the truck even with the rear brakes adusted up all the way.
tuckerd1
WAR DAMN EAGLE!
Princeton, AL
Yes, I installed the big MC. I didn't like the idea of widening the holes on the F350 MC.
It will stop on a dime now!;Sweet
