3/4 Ton-O-Fun
90F250 na7.3IDI 4x4
I just did the rear main seal and wanted to add somethings that might help those that care to read.
Icanfixall said "Just make very sure you get the joint at the oil pan flange and the oil pan really clean and use plenty of rtv at the juncture. You don't need half a tube there... Just enough to see it squeeze out some like the pan being attached to the block...."
Imagine this one, Icanfixall is correct. I hope my *** of RTV stays attached to the back side of the clean engine cover...
It is hard to *** paper towels into the opening to keep stuff from going into the pan while prepping the surface for RTV. If someone has figured out a trick, I didn't know about it.
My pic is the fel-pro twin lipped seal from O'riliey's. Notice how deep it is set? I set it flush to the inside of the engine cover. Had I set it flush to the outside, like the traditional one that came out, the outside lip would have been off the crank.
My mainseal was fine. The rear engine cover was leaking at the driver's side.
