How are the MR Gasketed turbo drain grommets working?
6 Nebraska IDIs
For those of you that have used them, how have they been working for you? Its been quite some time since I posted the info on the board about how I was putting them together but I never used them personally. I always ended up giving them with turbo kits I sold so I don't know how good of a solution it was. It sure looked like it would work well. The reason I ask is my brothers truck is leaking oil out of the turbo drain so I'll be installing one soon if I hear they have been a good solution for you guys.
Brimmstone
The setup I did is still working just fine. Absolutely bone dry as of the last time I looked at it.
eatont9999
TX
Will this work with an ATS 088? If so, I will be needing one soon. I also need to find some O-rings for the pedestal and both for the intake hat. The O-rings on my kit are old and hard, so I am doubting they will seal.
typ4
Newberg,OR
088m uses a stock cdr grommet IIRC. I have some orings but the rest are on order,
6 Nebraska IDIs
The 088 uses the stock CDR valley pan grommet. One of the few plus sides to that system.
Lance
