Jjona5
So I bought this parts truck originally to fix up my 95 powerstroke(needed some parts) and the guy said it ran fine but the front end was worn out and the hard lines started leaking so they parked it. Said it ran like a top before that. So I replaced the hard lines, fixed some other things, threw some batteries in it, and turned the key(had the fuel lines broke going to the injectors to prime). Absolutely nothing happened. I didn't even get lights on in the cab. So I disconnected the spade connectors, ran a jumper to the front spade on the drivers side of the injector pump and jumped the ignition solenoid. Once I got fuel and tightened everything up it ran line a top(minus a fuel leak). It hadnt ran in 7 or 8 years either. Well this engine is going to go into my 78 ford so I need to figure out how to wire up the glow plug relay and figure out what the rest of the spades on the injection pump are for. I can handle the rest.
Thanks in advance,
Jon
Thanks in advance,
Jon
