So I know a few of you have had problems with your Holley fuel pumps, and I've always said mine worked great, so I figured it was only appropriate that I come forward and say that out of the 4 of them that I've been running, I finally have one that is giving me trouble. The Moosestang which probably has 40K on the Holley Red, much of that running junk fuel is now having what I percieve to be a brush problem. I can always hear the pump run when I turn the key, so twice now I have turned the key and no sound. So I leave the key on and give the frame rail where the pump is mounted a whack with a broom handle, and the pump starts right up. The problem occured today, and then once before about a week ago. I suppose the motor has to land in just the right spot when I shut it off, for it not to start for me. Has anyone ever taken one of these apart to service the commutator and brushes? Seems like it should be doable to me if you could get the thing apart.
