heres an interesting question...
tjsea
Lickdale, PA
I had a head off of a 6.9 with the precups missing so I thought I would go out and just buy one of the chevy diamond precups and try it. The chevy pre cups are too small to fit in the head correctly, they do have a much larger opening in them. If I ever get the chance I may see if a machine shop can port the 6.9/7.3 opening to match the chevy.
Yes; you can "port" the precup "snout", but not more than .020 to .030 all the way around it, anymore will weaken it too much. For measurement of the port before grinding, take two large rubber erasure's and carve them to fit the port opening, that's your base measurement. On one of them, wrap tape around it to increase the size by .020, do the same on the other, but to .030, use a micrometer to measure, that will be the max grind out size. Thirty thousand's may not seem like a lot, but it's actually opening it up by .120 thousandths volume. A 1/4" carbide end mill in a die grinder is a good tool to do that. Should only take a week or two to do all 8. Have fun.
88beast
pa
or get a spacer made to adapt the precup?
The real problem porting a precup throat is you need to do it to 8 precups and they need to be the same. Otherwise the flame going thru them will be differant. Then you have cylinders making differant amounts of power and that causes a vibration. Its the same in a gasser when a spark plug is not fireing properly. That cylinder is low on hp... A CNC mill can do it best.
......take two large rubber erasure's and carve them to fit the port opening, that's your base measurement......
Wouldn't it just be a whole lot simpler to take and make use of RTV and sqeeze some into that opening a bit and on the face, let harden and press it out thus having a perfect casting of the pre-cup port opening?
JM2CW but it's what I would do to each one....:sly
placidoert
