This probably isn't it, but one thing to check is the brake lines going to the front brakes in the wheel wells. They are made of a flexible line so they can move around when you're turning the wheel. Alot of times they leak internally and cause this sort of thing, but they usually also create a pull on the wheel to one direction or the other when you brake because one caliper will recieve more braking force than the other. Anyways, it's worth a check. You can sometimes squeeze the brake line in your fingers and feel if there is brake fluid between the outter rubber hose and internal hard rubber piece that the fluid flows in.
