i was gonna start a new thread, but this one is on topic already.
will a ZF5 from a PSD bolt up to a 6.9? i found one at the junk yard today, and they ball-parked me bout $200 and a 6 pack of bud.
Here are the gear ratios for the 460 and diesel ZF5:
Diesel
1st - 4.14
2nd - 2.37
3rd - 1.42
4th - 1.00
5th - 0.77
Rev. - 3.79
460 Gas
1st - 5.72
2nd - 2.94
3rd - 1.61
4th - 1.00
5th - 0.76
Rev. - 5.24
All the gears are different except of course direct drive (4th). The gap between 3rd and 4th on the 460 ZF is a bit wider and a little noticeable when hualing, but you just need to hold thrid a few hundred more RPM before shifting to 4th, and it's no biggy. The lower 1st and Reverse are very nice when hauling that for sure.
Heath
can you swap the gears outta the trannys and into the other one, to mix and match? say, use first, fifth, and reverse outta the 460 tranny in the diesel one? and what are the gear ratios in a T19?
I just picked up another fresh rebuilt 460 ZF today. I'm just gonna swap bellhousings.
CAN you swap bellhousins on a ZF?? i thought they were cast one piece? if you CAN do it, ill use the ZF6 outta the F550 they had at the same junk yard and swap the bellhousin off of the PSD ZF5. (if it fits...)
