tractorman86
make sure you have the probe in close enough i actually started the truck and let it tap the dampner, back it out while watching the tach on the meter. dont know how to do it w/that piezo deal. the glowplug hook up is the most accurate way to do it in my mind. i'm sure you know but just to check you are setting the offset to -20 deg. right? my question is how do you adjust the pump and get it to stay ? i had a LARGE pair of channel locks on the front stem and got it to 8.5 but couldnt get it to stay long enough to tighten down the mount bolts, it just sprung back where it was possibly farther retarted than before .i about had a s#@% hemerage doing it, i guess being 115* and in direct sunlight makes one kinda tempermental.
