UMR_Engnr
I bought a 1989 F350 about a year and a half ago and it was leaking out of one of the injector return line caps. I let it sit for a few months and then started it up and then every injector cap was leaking as well as a few other spots in the fuel filter assembly. I had no idea how the leaks had gotten that bad, but figured it had to do with being old and sitting for a little while. I haven't been driving it, just starting it every once in a while. I wanted to start driving it so I decided to replace the return lines and fix the leaks. I replaced the return lines about three weeks ago, and it was pretty uneventful. After doing so I started the truck up and I didn't see any leaks out of the injector caps. I did still have leaks in the fuel filter assembly so I ordered a new style fuel heater and fuel olives. I replaced all that today and when I started it up all the injector caps are starting to leak like crazy again. Does anyone know what the heck is going on? My only guess is that the return line to the tank is clogged and causing the pressure in the return line to increase until it just leaks out the caps, but I don't even know if that is possible. Any help would be appreciated in how to solve this issue. Thanks.
