Headlight lens
junior20762003
VICTORIA TEXAS
I having hell taking my headlight lens out question is are you supposed to remove the fender or what I'm really stuck
gnathv
Athens, Al
What year is your truck? My 93, you have to take the batteries out and there are 10mm nuts that hold headlight housing to truck, remove these nuts (can't remember if there are 3 or 4 on each side) and the whole assembly pulls out the front.
gnathv
Athens, Al
Are you changing the housing or are you just needing to change the bulb? You do not have to pull the housing to change the bulbs. Hope this helps.
rjjp
Needs to go test
Clare, Mi
This is why I've been procrastinating on my lower corner bulbs, I don't want to take the whole assembly out.
Beads 93 idi
Brads 93 idi
kilgore Texas
I was jw because my truck was from Victoria and it looks like urs
It's a pain, and there is one particular stud that will drive you crazy trying to find it. You will have to remove the batteries, and possibly the battery trays to see things properly. I went through this on the Night Moose, but forget the exact nuance of what is involved, but I think it is in the neighborhood of the turn signal portion of the lense.
Seven4eight
