header flanges are in!
Over the years, IH has made many changes in the intakes for the V-8 diesel intakes. As we all know, the IDI is the big "H" shape with the inlet in the center of the "H". This was designed for a N/A engine with an intake mounted air cleaner (The big round, carb'ed big block style assembly). When the 7.3PSD came along, it was turbocharged by design. The turbo is mounted toward the center of the V in the valley, with the "intake spider" with the plenums that bolt to each head, with a "pipe" connecting it to the turbo. Next was the 6.0 (What I am most familiar with) they changed the design again. This application was going to be turbocharged and innercooled by design. But now throw in the wrinkle of the EGR system to keep "Uncle Sam" happy. The intake is now "U" shaped. The bottom of the U is at the front of the engine (About where the IP Gear Tower is on an IDI), and each leg of the U laying along the top of the heads. The turbo is located to the passenger side rear of the top of the engine, can is clocked with the turbo laying passenger rear to driver front at and angle. The hot side is toward the passenger rear, with the up pipes coming in an inverted Y from the manifolds to the turbo. The cold side is clocked with the intake pointed at the drivers front, and the cold out toward the passenger front with the IC tubes connected. The out from the IC comes up from the lower drivers side of the core support to the in port of the intake manifold. This location has 2 ports, one on top (facing hood) that is the cold in from the IC, and one on the bottom (facing valley) that is the EGR In. The design of this intake, is the bottom of the U is the fattest part. Each leg tapers in from the base to the #7 and * cylinders. The intake is much narrower at the top of the U than at the base. I am sure this is to help keep the velocity up to the back cylinders.
I do think you are on to something, with the equal length intake tubes on the IDI, in a turbo app. Or if they are not the same length, have the size of the pipe change accordingly. When the front cylinders (#1 and 2) would be "short and fat" and the back cylinders (#7 and 8) if the inlet was in the front, would be "long and skinny" to keep the velocity up.........
on one of these brain storming posts, there used to be a link someone posted for 409 SS 16 gauge mandrel u bends.
anyone recall which thread its on? or have the link?
time to order my u-bends!
the only reason i say 409 is because thats what most people carry with mandrel U bends.
this ones getting close!
i now have an engine, trans, transfer case, possible rims.
ordering those mandrel bends today,
only need a GTP-38.
have my TP38's
and my T-4 flanges in!!
i received my U-bends, only to sell them to a friend..lol
gotta buy some more!
hell youre the professional welder, im just a rookie that cant remember to turn his bottle off LOL
That's better than me. I forget to turn it on sometimes. What's disturbing is how long it takes me to figure out that I didn't turn the gas on. [emoji15]
sjwelds
Central KS
Well then you get them tacked up and I'll weld them! LOL No way man I'm sure your workmanship will be top notch, going by what we've already seen of it. ;Sweet ;Sweet :D
