Goofyexponent
Mentally Unstable..
Ok this has only happened once or twice before, but tonight was enough to make me jack the truck up and look for 20 minutes for a problem.
If I crank the wheel to hard lock while leaving an intersection (either direction), my steering wheel feels like it's binding up and won't return to center fully. I can make it go back to center, but there is pressure there that won't let the steering wheel center freely.
When I bring the wheel back manually, it's like the wheel pulls the front tires beyond center and the truck sort of death wobbles very slowly.
I can't find slack in ANYTHING. Spring bushing, shackle bushing, U bolts, track bar (mounts, brackets and bushing) tie rod, steering box bolts, drag link, pitman arm to steering box splines, cracks in teh frame or crossmember......there is virtually NOTHING. the ball joints are tight, all linkages are tight.....I don't know.
I know this, I am going to throw some ball joints and steering linkages at it.....replace it all for ease of mind. It's scary when it does it, but it's usually at low speed.
