the harness is not seperate. you need the complete harness from the auto truck. if you want to swap in an auto get a c6 and a gear vendors overdrive. way less headache. i personally love the manual. its alot more reliable than any electronic controlled tranny.
well that just rained on my parade. Did you just pull the wireing out from under the dash or take the dash completely out? Just wondering how hard it is to remove the dashes. The last wire swap I did was on an 83 with straight 6 and 4-speed, not many wires.
i just unplugged it from the firewall and used what was under the hood. i didnt want to pull the dash and all that if i dont have to but i may end up doing it still because the donor truck has a really nice interior but its red and would look stupid with a blue dash. im sure ill need to get in to teh evaporator and all the a/c stuff and clean it out so im sure ill find out soon enough.
i think with the e4od into a manual truck you will need the cab harness also. im not exactly sure but im sure it would be easier than fighting with the wiring gremlins that pop up.
