subliminal
i have an 89 f350 4x4 crew cab 5 speed and a 90 2wd auto, both 7.3's. the 89 has a destroyed wiring harness from an animal chew and the p/o's attempt to fix it. what i need to do is remove the harness from both trucks at teh firewall and put the one from teh 90 2wd into the crew cab. will there be any issues with this? from what i see it looks to be dang near identical. i assume there will be a few things extra on the auto vs the std harness but i would think it should be ok? does the whole harness unplug from the firewall? or will i have to remove the in cab dash harness too? if someone wants to post a link to some of the wiring diagrams i would be appreciative. i will also take soem good pics of the entire process and do a tech write up in this thread with the pics hosted from my server. that way if anybody needs info in the future its doccumented here.
