I put in new batteries and went with the higher cca ones that are shorter and they were not secure on the pass. side. The battery slipped into the condenser and radiator area. The gases from the ac were being released and there was a lot of smoke. I replaced the ground wire(it was toast), the bat. terminal(melted) and put in a bat. clamp. and replaced a couple fuses.
I have a meter in the cigar lighter and its reading 12.2 and at on time 12.4.
The 100 amp alt. will be here in the morn.
Is there any thing else that may have been damaged?
Thanks
Thanks
