94turboidi
Okay today while working on the truck the glowplug controller all of a sudden started smoking. I verified the wiring was correct a week or two ago and switched controllers from one I knew worked and it has been working fine. Well nothing has changed but now I can't hook up the glowplug main wire or it sparks. Its shorting out somewhere. I know thats what the glowplugs do is short out to create heat. Is that the only place it can ground to? These are motorcraft plugs.
I am considering wiring up a manual controller and trying to look around but if I do it I want to wire it all up from scratch to clean up this ancient wiring. They are 6 volt plugs right? They can't take 12 volt can they? If they could take 12 volts directly I was thinking that I could just use a starter solenoid and have a hot wire from the battery on one side and the other would go directly to all the glowplugs and the start wire would go to a push button. I dunno I am just thinking out loud. I would prefer to just simply fix my automatic setup. If I get a chance I will get a picture of it but its hooked up exactly like a pic I found on here, I think OLDBULL posted it showing which wire goes where. So maybe now that my motorcraft plugs are actually putting a good draw on the controller compared to the autolites something burnt out but what? I thought about buying a new relay or whole controller but wanted to get some ideas first.
