TheBAT
Is it best to use a rocking back and forth motion or a twisting motion if one is stuck? Also, do you think they are the glow plugs?
Kev
Kev
A piece of rubber fuel tubing about 12" long works good after you have it loose. Just slip it over the GP and turn it out, reverse for install.i wish they mad a socket for loosening the glow plugs all the way, as if you loosen the glow plug all the way with a socket, it gets wedged on the injector
