tbirdfiend281
A piece of rubber fuel tubing about 12" long works good after you have it loose. Just slip it over the GP and turn it out, reverse for install.
im actually thinking of cuting a socket to size. or grinding a long 1/4" socket down so it can slide past the injector when it is still in
i have to go to sears since they are cheap, and make my socket
ive mastered the 6.0 oil rail torx bolt problem with a custom speacail tool, i think i can nip this one in the but also
