There is NO NEED to remove the INTAKE, just the AIR filter housing...cover that hole if the screen is missing and cover it anyway so no debris gets into it!
As mentioned it's a matter of removing the wires, and carefully undoing the GP's if you find resistance when attempting to pull them out...STOP, get some KROIL, WD 40 , PB Blaster, or just about anything that you can squirt down the hole and let soak and hopefully loosen/dissolve carbon build up. As well it helps to lube the tip when attempting to withdraw it from the GP bore.
Biggest issue won't be carbon it would be a swollen tip. This again is patience and perseverance to overcome the issue.
Just don't go yanking on anything stuck, come back here and describe issues thoroughly findings of other plugs etc. this is a matter of better to wait...and find out best suggestions..than not wait, break stuff and end up worse than before starting....
JM2CW but others will chime in...
Al
