It has been a fun week, I found more reasons to poke the Ford engineers in the face, but it is over with and done now.
Tanks are clean, inline fuel filters just after each tank, new fuel selector valve in place, (bit the bullet and got the OEM, it just made things easier and I found it for a exorbitant decently price), rubber portion of all fuel lines replaced, Facet/Duralift pump mounted. Now comes the fun part, I have the Painless fuel pump relay kit, no issues there, what I am looking for is a better way to tap into key on power than the FSS or running a wire to the fusebox. I know I may be forced to run into the fusebox and I know there should be a grommet on the firewall by the brake master cylinder, but I have not found it. I really don't want to tap into the FSS.
Has anyone found a better place to run the key on power from under the hood? There is a large distribution block by the washer reservoir but I doubt any of those are ignition switch controlled. I have searched a few different forums (this one is still the best) but seems everyone either does the FSS or runs a wire.
Edit, this is on the 94.
