Flagship
I have an 89 F-350 with a 7.3. A couple of months ago, I got the light that said I had water in my filter. So, I got under the hood, in the dark, and turned the bottom of the filter to let the water out. I didn't see anything come out of the bottom of the filter, so I turned the ring some more. Still nothing. I turned the ring some more and (as you've guessed by now) the whole bottom came off! THEN I noticed the hose connected and figured that was the reason I didn't see anything. Of course, the o-ring was swollen, the filter was empty, it was night, dark, cold and I was more than a little embarrassed. Next morning I went to the local parts store to get a new filter. They had only a Wix filter, with a little plug in the bottom. No water sensor. I put it on temporarily.
So last week, I got a new filter from Ford. The correct one. $42!!! However, when I put it on, I found two wires that could be connected to the bottom of the filter. Naturally, I can't remember which one is correct. One, a green wire with a red tracer has a slightly bigger rubber connector covering but same size connector. It's quite a stretch to get it to reach. The other is black with a smaller rubber covering on the connector but will reach with much more slack.
Can someone tell me which one goes on the filter? And, what's the other one for?
