Fuel filter light comes up what could be the cause?
Bart F-350
FRANCE
How much importance have these shower heads?
in my rear tank there was non, and in my front tank it was sooo brittle that when I was taking that unit out, it broke off and dropped in the tank.
The silver lining around the cloud is that I'm taking out the tanks to have them steam cleaned to get rid of these algae in the diesel.
It's common for people to take them off and just put a small piece of hose on the end of the pickup to get to the bottom of the tank, and cut a V in it so it doesn't suction itself to the bottom of the tank.
Bart F-350
FRANCE
So, Today I got around to cut the filter, it doesn't look like much, but it defenitly spoiled my week, to clean everything etc.
At the filter base where the sensors are, you see the slight brown layer, I think that's the "pesky bacteria", that is in the tank as well, and in the diesel entry line from the filter head etc.
Bart F-350
FRANCE
some more:
If you look at the paper filter itself, it looks not bad? I was suprised to see that, until you look a bit better on the unfolded "harmonica", there you see that the whole filter media is covered with this sticky tough layer of lightbrown "goop"!
Bart F-350
FRANCE
I wonder, I still need to clean the pick-up units (with fuel level sender) but just in case I might be a bit too harsh on them, are they still available new? for the metal in frame tank, and the plastic behind the axle tank?
Bart F-350
FRANCE
Bart F-350
FRANCE
I have no Idea why, but most plastic (or rubber) parts desintergrate when you touch them?
Does anyone have a design how they should be? in order to get the fuel system to work again?
Thank you in advance.
Tristan
Federal Way, WA
You can just run a length of fuel rated rubber hose. Just angle cut it or make a T so it doesn't suction on the bottom of the tank.
Bart F-350
FRANCE
Done, tanks are all clean, I cleaned these pick-up assey's, cleaned the lines out, am busy installing a cheaper temp.filter and then filling up the tanks with new proper (treated) diesel and off we go!
Bart F-350
FRANCE
and now we are in Okt, and I noticed a newlayer of bacteria forming in the transparant bowl of my fuel filter!
Dang! those Idiots don't make the diesel anymore as they did before!, over here, now I see more than one vehicle a week suffering from this B*$$%&it, GGRRRR, it almost makes you throwing a spoon of sulphur in the dieseltank!
Minuteman96
Sierra Nevada
Run some DeiselKleen in your fuel tank. It’s designed to help with the low sulfur diesel fuel were forced to run nowadays.
Bart F-350
FRANCE
I noticed that they have: a gray, a white, a silver and a green bottle.
you are talking about which one?
Gray is for all year round, white is for winter, has added anti-gel additive.
