beretzs
Well, the shop I took the truck too, STILL did not get the returns lines correct. It starts really hard in the morning, but fires right away after it is warm. Plus, I can see where there is fuel dripping from the back side of the engine and leaves a spot on the ground when it sits. So, I figured I would get in there and see if I could fix it, even though I wanna take it back up there and tell them to fix.. First off, I tore all that Banks Ram Air crap off, the ducting that comes all the way from the grill and the mount that used to hold the canister up. Look pretty nice now, clean looking and I can hear a little turbo noise when I have the windows up, no real difference as far as I can tell with driving, maybe a little faster boost, but nothing to write home about, just gave me a good picture of where/routing the intercooler tubes will go to. Overall, it looks pretty cool with the K&N just hanging there off the cast inlet elbow. I like it, and since it hasn't degraded performance and will probably actually help out on the open road I am all for it and would reccomend it to anyone with that funky Banks Ram air. They should have done it like that from the git go.. More money to put all the extra plastic and brackets in there..
But, even with all the new found space, I still could not find the leak. Kinda sucks, being I HATE fuel leaks, but it is liveable for now. I will probably take it back up there this week and have them fixer up correctly. I did finally move my external fuel screw out the last couple of threads, I had it pretty well out, but just wanted to make sure I was getting all she had. The truck does run really GOOD now though. I would like to run a few 0-60's for you guys, but until I can afford to blast away some fuel, I will wait. Scotty
